Vaio vgn-AR71ZU wont Boot
ncgreyfriars
When i switch on the unit i immediately get a black screen and 1 long beep followed by 2 short beeps
i have tried connecting ext video
with and without Battery also HDD's also Ram and Optical Drive does anybody have any ideas what to do
rich912
The beep code would suggest a problem with the graphics chip.
If changing/reseating RAM and attaching an external monitor have had no effect then I suggest that you contact one of the Sony service partners for a repair.
Be aware that this will be costly as it will possibly require a replacement mother board.
http://support.vaio.sony.eu/computing/vaio/contacts/asc.aspx?l=en_GB&m=VGN-C2S_P
Go n-éirí an bóthar leat
