Ich habe seit heute ein problem mit meinem 2 monate alten laptop.
Der bildschirm geht nicht mehr an, doch der pc macht geräusche und 3 grüne lampen leuchten neben dem anschalter. es kann jedoch nicht an der batterie liegen, da ich den netzschalter ebenfalls angeschlossen habe und er nicht ging!!
Vielen Dank im Voraus
schamong07
hi guys,
my new vaio suddenly doesnt start anymore. the screen shows nothing, although one can hear the pc running. It cant be dependant on the battery because with electricity it also doesnt work.
thanks
schamong07
Hi schamong2007 and welcome to Club Vaio.
Have you added more memory? This sounds like a loose memory stick.
If not, then I would contact Sony Support HERE
Thank you for the advise.!! I will try to call the support center of sony.
I think I can send it in to let it be repaired or exchanged, as I have still 2 years of warranty. I really have never had this kind of problem. Even if i press the f8 button the pc doesn't react.
Thanks for the kind help
schamong2007
