VAIO VGN FS-315M
Audiboy
VAIO VGN FS-315M
Hello,
Is WINDOWS VISTA for my VAIO VGN FS-315M capable?
Thnx
4 REPLIES 4
Hi Audiboy,
I would download and run Windows Vista Upgrade Advisor which will scan your system and tell you if it can run Vista.
Looking at the specifications of your FS315M, I would expect it to be able to run Vista, even including Aero, if you fill it with the maximum 2048MB of RAM. It may not be very fast because Vista requires powerful hardware which is more likely to be available in newer models.
:wink:
Audiboy
wich type of RAM do I need for my FS315M?
You will need the 2GB Kit for €41.11 from here: -
http://www.crucial.com/eu/store/listparts.aspx?model=VAIO%20VGN-FS315M
Here are the instructions to install it: -
http://support.vaio.sony.co.uk/tutorials/memory/memory.asp?m=2004&site=voe_en_GB_cons
:wink:
Audiboy
Thank you for your information!
