VAIO VGN-SR520G Batery life
emidiocunha
I have just bought a Vaio VGN-SR520G Notebook in a Best Buy store in New York. At the Best Buy site on the internet it says that the batery would last for 6 hours. This is not true. My fully charged batery lasts only for 02:34 hours. Does this happen to someone else?
Emidio Cunha
Joao Pessoa - PB - Brazil
13 REPLIES 13
83735935
I have a VGN-CS31S and the battery on that does not last the full time stated however I read somewhere that it all depends on what you are doing on the laptop, i.e. if you are viewing music videos then it zaps the battery quicker.
I also have a Dell D630 and the battery life on that is much better.
However I think it also depends on the amount of cells you have in your battery, i.e. 4, 6 or 9 - 9 lasting the longest, being the heaviest and most expensive. I was not given the option when I purchased my laptop to upgrade the battery so I assume Sony only do the one flavour??
It's worth contacting the Vaio Support people to see if you are getting what you should form your battery just in case there is something wrong with it.
profile.country.de_DE.title
itbroker
Caro Emidio Cunha,
Seja bem vindo ao Club Vaio !
A informação oficial é :
Battery Type: Standard Capacity Lithium-ion Battery
Estimated Battery Life: Up to 6.5 hours Standard
Capacity Battery
Up to 9.5 hours Large Capacity Battery
Power Requirements: 121W + 10%
Se por algum motivo o computador não está atendendo a este standard, é realmente porque há um problema com a bateria.
Vc. deve contactar a loja onde vc. comprou para que a troca seja efetuada.
markj1993
Wow you're very lucky in my eyes. Mine has never lasted longer than an hour and a half, but for some reason now, whenever i dont have the charger plugged in it shuts down the laptop within 2 minutes, so basically the battery doesnt even matter. When my laptop restarts it says the battry is 85% or 90% charged so i don't see a reason for this happening. I have been on the power settings and made sure every setting says never turn off.
Anybody got any ideas what is causing this?
83735935
Hi All
Thought this might be useful to explain the battery usage
Sorry its a bit small, still getting to grips with putting pictures in the forum.
:thinking: Question to Sony Vaio Experts: Is there an upgraded battery we can purchase, I assume the one that came with my laptop is only a 4 Cell battery - can we purchase a 6 or 9 Cell battery etc?
rich912
Hi Jan,
Have you tried Sony Style?
Click HERE
This is a 9cell battery that is compatible with your model. Doesn't come cheap...
Go n-éirí an bóthar leat
83735935
Hi
Yes had a look but in the around £170 so will keep plugging in for now, unless father christmas is generous this year!
emidiocunha
O problema é que comprei o meu vaio em Nova York e moro no Brasil. É umapena que uma empresa do porte da Sony não disponha de uma garantia mundial. Provavelmente isso significa que eu e outros que compramos esse computador teremos de arcar com uma bateria que não atende o que espcifica no anúncio do computador. Isso é simplesmente lamentável.
Atenciosamente,
Emidio Cunha
Caro Emidio Cunha,
Capacity Battery
itbroker
emidiocunha,
Em tempo : Observe que o Jan13 explicou muitíssimo bem os tipos de bateria existentes e Rich912 indicou a Loja virtual da Sony.
Se vc. decidir comprar uma nova. Vou a SP ABRIL próximo a negócios e posso entregar à vc. pessoalmente.
Tentarei falar com a Sony diretamente para tentar encontrar uma outra solução. Preciso de alguns dias, Ok ?... :smileygrin:
emidiocunha
OK!!!
O Problema é que eu moro no Nordeste, em João Pessoa - Paraíba. Caso você realmente possa trazer a bateria para São Paulo eu posso pagar o frete da mesma de lá até aqui.
Aproveito para lhe agradecer a atenção e também para lhe desejar um FELIZ NATAL e um ano novo repleto de realizações e muito sucesso.
Atenciosamente,
Emidio V. L. da Cunha
