Vaio VGN-T2XP driver install for a newbie
Steve755
My treasured VGN-T2XP has suffered a hard drive failure and so I have fitted a new drive. I bought the laptop second hand and never got any recovery discs or OS installation discs.
I have installed XP pro from a disc I already had and downloaded the "originally installed" drivers bundle from the Sony support site, but how do I install them? The WirelessLAN driver was easy as it had a .exe but some of the others (like video, chipset etc.) are beyond me. I'm stuck with a screen resolution of 1024x768 with the default driver for the display.
I'm a relative amature at computing so I'm hoping you guys can sort me out???
rich912
Hi Steve,
Below is a guide for XP to installing drivers that have an INF file instead of an EXE in the driver package.
  1. Extract the files from the installation package to a known location.
  2. Click Start > Control Panel.
  3. Double-click the System icon. Note: Select Switch to classic view if the system icon is not visible.
  4. Click the Hardware tab.
  5. Click Device Manager.
  6. Click the + symbol in front Device Category to expand the section, or look for a device that has a yellow warning symbol indicating that drivers have not been installed.
  7. Right-click the Device and click Properties.
  8. Click the Driver tab.
  9. Click Update Driver.
  10. Click No, not this time and click Next.
  11. Click Install from a list or specified location and click Next.
  12. Click Don't search. I will choose the driver to install and click Next.
  13. Click Have Disk....
  14. Click Browse and navigate to the folder where you placed the extracted files.
  15. Click OK.
  16. Click Next.
  17. Click Finish.
  18. Reboot your system if requested.
Rich
Go n-éirí an bóthar leat
5 REPLIES 5
rich912
Hi Steve,
  15. Click OK.
  16. Click Next.
  17. Click Finish.
Rich
That will almost certainly be the MemoryStick Slot which needs the Texas Instruments FlashMedia driver.
You can find this in the Original Drivers Package -> MemoryStick and use the above method to point to TIFMSony.INF
:wink:
Steve755
Cheers Rich, this worked a treat. I now have a full screen of desktop :slight_smile:
I still have one yellow question mark against "Mass Storage Controller" in Device Manager. I have tried all the obvious drivers in turn from the Sony download package but none seem to be accepted as suitable. Do you have any suggestion for this? Can I get the driver for this from elsewhere?
Steve755
Thanks, that worked a treat.
Rich912 and Blencogo.......you're both Hero's of my day!   Many thanks, Steve.  :smileygrin:
rich912
You’re welcome Steve :slight_smile:
