VGC-V2M issue with sound level via remote control
profile.country.fr_BE.title
PhotoLight
As the restore utility of my VGC-V2M refused to work, I have formatted the hard disk drive.
After installing the drivers and utilities found on
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?m=VGC-V2M&l=en_GB
I still can not adjust the sound level via the remote control.
Do you have any idea of what I should do to fix the problem?
When  I use the remote, it shows a full or empty level but the gauge does not  increase the levels progressively and it has no impact at all on the  sound level that remains the same.
I installed Windows XP Pro FR, with SP2.
Thanks for your help!
Tags (3)
0 REPLIES 0
