I have a Vaio VGN-A417M and the dvd drive doesn't recognise cd's, i can't read or write cd's.
I have tried to download the update files, but i can't seem to download them ?
has anyone got the file they can email me, or tell me how i can access it ?
SOACTD-00805805-UN.exe is the file name
Hi Illusion,
The file you mentioned is for the Click to DVD 2.4.12.14100 Upgrade, there is a firmware update available for Sony DW-D56A optical drive (SOFOPD-00829906-UN.exe)..:smileyconfused:
thanks for that, i downloaded that a while ago, just doesn't seem to work.
Tried downloading it again, but can't access the ftp site either ...
Hi Illusion,
Do you have the Sony DW-D56A optical drive on your A417M, as not all vaio's carry the same optical drives?
Hi Illusion,
Hi Illusion,
Goto start > Control Panel > Performance and Maintenance >system
Then select the Hardware tab and click on Device Manager, click on the + next to DVD/CD-ROM Drives to display your make of drive..:smileyhappy:
hi thanks for that, i have that drive,
Also did a search on google and it seems i am not the only one where it doesn't work ..
http://forum.us.dell.com/supportforums/board/message?board.id=insp_cdrom&message.id=42039
http://club.cdfreaks.com/showthread.php?t=139009
http://www.cdr-zone.com/forum/about4768.html
Yeah it's a universal problem
