HI,
I have a A497XP and have just purchased the VGP-PRA1.
I can't seem to be able to the TV tuner in the VaioZone, appreciate some assistance.
In addition, in system devices, the ATK0100 ACPI Utility has a conflict, how can I correct this? Please assist.
When I plug in a USB 2.0 device, there's a pop-up asking user to plug in the device into another port. How do I fix this?
This is my first Vaio appreciate some assistance.
This thread shows how to use it :
http://www.club-vaio.com/clubvaio/mvnforum/viewthread?thread=25823
(Note that this program only works when pointing to existing directories - it won't create them for you).
Once the .pac files have been unpacked, browse through the output directories until you locate the remote commander setup and launch it.
BTW, don't forget to save the program so that if you have to re-install Windows you'll have it without re-doing the procedure.
Sorry dont understand, whats this mean,Open up the command shell and unpack all PAC files by typing in
is there a prog that will extract the files I need for the remote control, I do not understand please help
Can someone help?
Can no one jive me a hand with this?
Come on guys, surely someone can help?
