Hi there
please can someone tell me where i can buy AR series housing parts lets say my laptop is scratched and i want to change housing parts with new ones. is it possible and can i order part online? thanks. i can change them myself.
Best Regards
Djordje Vujicic
Hi Djordje,
you may be able to find the parts at nexttronics, use the following link for details: Nextronics
thanks a lot man!
i have found it, but just on the picture
the part that i need is number 84 under B-1.Bottom
http://www.nexttronics.com/reference/sony/ar3/int-AR72DB.htm
but i dont see that they are offering it.
Try contacting nexttronics by email and ask if the parts available..
