Has anybody noticed when you resize a window or scroll down a web page a strange clicking coming from under the keyboard. I think it is normal or maybe not. This is the first time i have noticed a vaio doing this.
Also a strange low level clicking coming from what i think is the hard drive.
Getting a little annoying.
Anybody got any suggestions?
I have got an AR11M and dont notice any of those sounds that you have mentioned. maybe it mite be different for the AR21S. may be another AR21S user could post if they get these noises or not.
Could be a few things!
It could be coming from your Graphics Card and can also happen when you move windows around the screen. I don't think it is a problem.
Try turning off "Use Smooth Scrolling" in the IE Tools>>Internet Options>>Advanced List.
