I keep getting 'a drive in RAID 0 is failing. Try to Back up data immediately' error on my 2 month old AR61ZU.
I checked these forums and there was an issue with Intel Matrix Storage Manager and Quicktime. I've updated to the latest intel drivers (7.8) and the problem remains.
Could it be that the message is correct and my hard drive is actually failing? I suspected it might be so ran checkdisk and it failed to complete.
If it is a legit hdd failure, how will this be repaired? Will sony send me a new hdd and allow me to replace myself? I only ask because this is my work laptop and it would be seriously inconvenient to be without for any length of time - I've just about resigned myself to the possiblity of re-installing and configuring the laptop again after a restore, i hope this isn't prolonged by having to send the laptop of for repair.
Many thanks for any advice..
Hi BimmerJimmer,
welcome to Club Vaio..
Have you installed the Intel SATA Driver 7.5.0.1017 from the Sony Vaio support site?
If not use the following link to download the update: SATA Driver
Sony state: This update resolves the following issue:
- Degraded RAID volumes when playing or transcoding video files in Apple iTunes and QuickTime software.
Thalamus is right - the new SATA/RAID driver should fix the issue.
Unfortunately the error message persists until you manually re-set the drive: -
1. Search all programs -> Intel Matrix Storage Manager -> Intel Matrix Storage Console
2. Right-click and 'Run as Administrator'
3. In the Intel Matrix Storage Console, choose 'advanced view'.
4. One of your drives ("Port 0" or "Port 1") will show an error.
5. Change its status to 'Normal' (I think you do this by right-clicking on the drive or choosing 'Actions')
Good Luck.
I installed updates late last night and reset the error message in the matrix manager.
So far so good. Fingers crossed.
Thanks for the advice.
glad we could help..
Yep, keep your fingres crossed, there could be a faulty drive, between the two hdds, happened to me on my AR31S, updated the drivers but the same message haunted me everyday, until l removed the hdds n checked each one independently on my hdd enclosure , & jus when l thot everything is fine, l heard clicking noises in one of the drives, it seemed as the read/write arm was stuck & couldnt move past some point...
Boo Hoo, updated the driver and still getting the errors.
How do I arrange a repair? Can I just phone a Sony Centre shop? (I bought online)
