Vgn-ar88e graphics card
terrythedj
I have just installed a new hard drive into my vgn-ar88e, I dont have the original disc's and I have just installed windows 7 64bit but I am struggling with the graphics card I believe that the card is an nvidea and after going onto there site I canot download from it as it insist's that I download from sony drivers,But I dont know where to find the 64 bit driver for windows 7, I can get the 32 bit but these dont seem to make any difference please help if you canj.
rich912
Hi terrythedj,
If there is no 64-bit driver released by Sony for your model you will need to use a modified INF file for the system to accept the Nvidia driver.
Have a look at the following link and read the Quick Start Guide towards the bottom of the page.
http://www.laptopvideo2go.com/drivers
This procedure is of course at your own risk...
Rich
Go n-éirí an bóthar leat
rich912
Hi terrythedj,
Rich
