[VGN-C1Z] Bluetooth Software/Drivers
Channi3
Hi, I've just re-installed windows xp without the extra applications. Everything is working ok but i do not know where to download my bluetooth software.
Any idea?
You will find the drivers in the Original Driver Download for your model: -
To Install Run: -
C1_Drivers\Drivers\Bluetooth\Setup.EXE
You will find the Bluetooth Stack in the Original Utilities Download for your model: -
To Install Run: -
C1_Utilities\Utils\Utils Installer Bluetooth Stack for Windows\Setup.EXE
:wink:
