VGN FZ21Z VISTA 64BIT DRIVER
fubbe
hi,
i just recieved a copy of windows vista business 64bit. well my following question refers to the graphic drivers, is it possible to get 64bit nvidia driver for the gforce 8600m gs, for i couldnt found anything on the sony driver page.
greetz
6 REPLIES 6
Hi fubbe,
Try this one: -
http://www.laptopvideo2go.com/forum/index.php?showtopic=15050
nVidia 8600M GS is included in the original .INF
:wink:
fubbe
hell, thanks a lot man u really saved my day!
edit :
are u sure about the original *.inf because the nv_disp.inf just shows the 8600 GT.
My mistake - yes you will need to download the Modded .INF and swap the nv_disp.inf files. It is definitely in the Modded .INF!
I had a quick look and saw the 8600 GS and mistook it for the 8600M GS
Good Luck!
:smileyd_oh:
fubbe
where do i get the modded one, or am i able to add 8600m gt by myself?
At the top of this page: -
you will see "Driver" in black and "Modded .INF" in green.
Click on "Modded .INF" and choose "Save" - save the file to a temporary folder or to your Desktop.
Full instructions are given here of how to install: -
http://www.laptopvideo2go.com/forum/index.php?showtopic=33
:wink:
fubbe
awesome! it seems that u possibly should spend more time on fresh air ^^ keep on the good work!
