VGN-S4VP Dislodged Shift Key
charfieldstfc
My damned cat has just pulled the large shift key, on the right of the keyboard, off. Any ideas on how to replace it please?
I have 4 pieces; the visible key itself and then 3 small bits ( 2 black and 1 white). I've tried a couple of times but always end up with the long side nearest me not seated. Ideally I need to know how the pieces go together and then to put the assembly into place.
Alan McCann
Thalamus.
Champion
Hi Alan,
I've sent you the Key replacement guide in a Private Message, click HERE to view your messages .. :wink:
I hope the guide helps.. :slight_smile:
charfieldstfc
Many thanks Thalamas
Thalamus.
Champion
You're welcome Alan.. :slight_smile:
