Hi!
does anyone had or have the same problem ?
Sometimes my Mousepad works reversed,.. when i want to go to the right, the mousecursor moves left,... same with up and down.
is this a error, or a feature ?
You are not alone with this problem as another vgn-sz2xp owner has reported the same problem – have a look at this thread.
I suggest that you raise a case with Sony support as we were unable to find a long term solution for jaz.
