Virttual memeory / total paging file size for all drives
mattaitken42
Hi
I increased my Virtual memeory / total paging file size for all drives on my FS215B to copy video to dvd from my camcorder but did not make a note of the default settings so i can change it back. There is an initial size and maximum size. Can anyone tell me what the default settings are? Its in control panel > performance and settings > system > advanced > performance options> advanced. Click change to look at the settings for initial and max size.
Matt
Thalamus.
Champion
Mine states 1536mb initial size and 3072 maximum size :slight_smile:
Also under the custom setting it should state recommended initial size
mattaitken42
Mine states 1536mb
Thanks. Does it have initial and max size when u click change?
Thalamus.
Champion
