Hi, I recently purchased a new sony vaio vgn-c2z however when i try to connect to my wireless router i can only connect to it locally however when i plug it into the router it works fine, can some please help!!!!
double click on the wireless icon in the task bar and bring up the dialogue box that shows a red cross through it interupting your connection toi the internet. Click on the greyed out world image and voila internet should connect. If not check your firewall settings are not over enthusiastic.
