Vista Upgrade
highroyds
Vista Upgrade
Hey all,
I clicked on the link for the express upgrade for vista and found I could pre order it through sony. Now I clicked on the link and put all my details through, but when I got to the end it said if I cancelled the order I would need to contact customer support to reactive the order. I closed the window thinking the order had gone through, but I've yet to receive any confirmation and when I put in my COA to check the order it says theres nothing on order.
What do I need to do ??
Any advice ??
Thalamus.
Champion
Hi highroyds,
I would contact customer support, as you would not want to order two copies of Vista.. :wink:
tuffnut
Try calling the Vista Upgrade centre on 00800 666 44 666
