VPCS11X9E can't connect to Internet
dfmcunha
Have a VPCS11X9E that cant connect to Internet. I have searched for the solution on the Internet and have found nothing.
Have Windows 10 64bits
Can't connect to internet
USB mice doesnt work but pens do
What can I do to solve this issue as fast as possible
Hi dfmcunha and welcome.
Have you just installed Windows 10?
Sony only supports Windows 7 on your Vaio and this sounds like a missing Network/Wifi driver and/or SFEP driver.
You can search the web for a compatible driver or you could ry reinstalling the Sony original driver from the downloads support page here:
https://www.sony.co.uk/electronics/support/laptop-pc-vpc-series/vpcs11x9e?downloads-num=61
dfmcunha
The internet was working fine on Windows 10, its not a fresh install
