Vvaio vgn-sz3vwp/x with a 120GB SATA hard disc. What is maximum hard disc I can install?
ian9042a
I have a vaio vgn-sz3vwp/x with a 120GB SATA hard disc. I would like to establish the maximum size of replacement I can achieve with the system. Any issues on doing this? Can anyone help please.Many thanks.
I don't think there is any limit for your model. On some older computers issued prior to XP SP1 there was a limit of 137GB but your model is much later than this and came with SP2.
Just be aware that you need a slimline 2.5" SATA drive no thicker than 9.5mm.  These are now available up to 1TB.
http://www.dabs.com/products/samsung-1tb-spinpoint-m8-2-5--sata-3gb-s-5400rpm-8mb-9-5mm-7KWF.html
If you need disassembly instructions, send me a PM with your email address.
:wink:
:wink:
