w2 XP Service Pack 2
msmmarion
After installing SP2 the speakers stopped working on my W2. The headphones do work and I have tested it without the headphones plugged in.....
TygerTyger
Sorry to state the obvious, but have you made sure all your volumes are turned up? Unless the speaker itself has broken which is rare, I would imagine it's just something in your settings, since the sound card works. Have a good look and see if you missed something.
