w2
jamesv3s
w2
i have a v2 machine, can u tell me if this pc will be able run vista , i know the graphic pwer is only 32mb, but u tdoes have 208 proicessor and sufficient ram.
Thalamus.
Champion
Hi james,
You can check whether your Vaio W2 can support Vista by running the Microsoft Upgrade Advisor. This will scan your system and produce a report.. :slight_smile:
