is there a way to use a digital tv card instead of the build in analog tv card of my RA 304?
The build in tv card is connected to the front panel (audio cinch). So is there a digital card on the market to replace the analog tv card (without loosing any funtionaity on my RA 304, hardware AND Software)? Does anybody tried it?
Greetings
Ralf
No, there's no way of doing this without changing software
Yes it can be done with a Haupagge card, but you'll loose VAIO Zone (not a bad thing if you ask me)
