What driver do I need for "Base System Device" on a VPCEB1E0E/WI ?
tangram55
Ive recently had no option but to wipe the HDD and reinstall Win7 from scratch (long story!).
Ive managed to install all of the drivers except one and I cant identify the one I need.
In device manager under "Other Devices" it says "Base System Device" with the yellow exclamation mark, but neither Windows Update nor Vaio Care/Update have helped.
Which driver do I need ?
It is usually the MemoryStick/SD Card Slot Drivers that get overlooked.  Have you installed the 3 Ricoh Memory Card Drivers from here?
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VPCEB1E0E_WI
However, it could be the SFEP driver.  What is the Hardware ID shown in Device Manager under the 'Details' Tab?
:thinking:
:thinking:
tangram55
Ahhhh thats logical :slight_smile: Thanks, Ill try that.
In the meantime Ive attached an image of the devide IDs
tangram55
Yayyy, thanks again, it was the memory card :slight_smile:
