HI, I HAD PROBLM WITH MY NOTEBOOK, ITS BRAND NEW BOUGHT FROM PC WORLD STORE.
WHEN I SWICHED IT OFF IT DOES MAKES NOISE. IS ANY ONE KNOWS IF THI IS NORMAL.
BECAUSE I HAVE WARANTY WITH IT SO I SEND IT BACK 2 TIMES, AND THEY SAID THAT IS NORMAL.
I DNT BELIVE WHEN LAPTOP IS SWICHED OFF IT SHOULD STILL MAKE NOISE. I CONTACTED SONY MANY TIMES AND ALL THEY SAY THIS IS HOW IT SHOULD BE, ITS BX SERIES.
ANY COMMENTS PLEASE?????
It's normal - it's the sound of the dymo in the unit converting the electricity to the right voltage.
Please don't use capitals - it implies you're yelling at us.
Hi, Thank you for reply, Do you think when its swiched all the electronic parts shoulde be swiched off too?. I never seen any other electronic devices are makes noise , when they are swiched off. Why do you think this noise if you think its normal? All the electronic parts in laptop should be off and no need to work ?
Thx again.
