Where can i get the software included in my preinstallation
iis-media
I Want to install winXPpro on my vaio. I need some funkitons for use in a domain environment. I have a licence of my own?
thanks for your effort
7 REPLIES 7
rich912
The applications will be on the recovery disks, assuming that you have created them, but be warned that the installation of these on your own version of XP is not always straightforward.
Go n-éirí an bóthar leat
iis-media
The performance suffers under the needless softwate elements. I am afraid thad the system driver are optimized for XPhome and there are problems expected if i update to XPpro.
That is not OK. Wy do they not deliver the notebook with the application cd`s? I only wan't to install a new system like all Admins in the world. The Adobe Software is necessary for my work.
rich912
The drivers are identical for both XP Home and XP pro.
Sony are not alone in this, have you created your recovery disks (media).
iis-media
Thanks,
yes i create a 2 dvds for applications and the system with the recovery tool. I think i understand what you want to show me below. Am i right that i only have to install the recovery tool after the new installation of WinXPpro and install after this, the applications with the recovery tool?
rich912
In theory you should be able to get the Application Recovery Wizard to work by following the procedures outlined in this guide (ignore references to US links and download any necessary drivers and utilities from Vaio-Link), but judging from many posts in this forum it is certainly not always the case.
Alternatively download the pre-installed Drivers and Utilities (from Vaio-Link) and install these after your clean install of XP. Then use an application called kcap to unpack your recovery disks and install any Applications that you want. Have a look HERE.
iis-media
Thanks Rich,
it was a pleasure to communicate with a profesionall vaio expert.
ISI
rich912
You're welcme ISI. Best of luck with the clean install.
