Hi everybody,
I haven't be able to find any drivers for the graphic card of my Vaio PCG-K295HP: the ATI Radeon IGP345M !
It's really boring that there are no place to find up-to-date drivers for this card, even on Sony Vaio-Link site !
Please could you tell me WHERE to find that ?
Thanks !
http://www.club-vaio.com/clubvaio/mvnforum/viewthread?thread=13898
Ce pilote d'affichage n'est pas compatible avec la (les) carte(s) graphique(s) installée(s) sur votre système.
This display driver isn't compatible with the graphic card(s) which is(are) installed on your system.
I don't think anyone issued a new drive since.
The bad news is you can't, if there's not one on VAIO-Link, and the Omega ones do not work then there's not much that can be done.
It's very annoying and Sony need to address this.
kee-lo thank you very much for your support.
Omega drivers look to work, it recognizes my card as IGP34xM (x means 0 or 5 i think)
Good luck with those drivers.
If they won't work then you will find out soon enough, they just won't install. Or they may install and then not work 100% but this is one of those times where you have no option sadly.
