I used to be able to shut the laptop lid and download torrents over night , all night ., with older utorrent versions.... Though , now as soon as I shut the lid , my torrent download speed slows down to 0-5kps
Before you say "check your power options ", I have already optimised them . I have made sure by changing the options that the computer doesn't sleep, hibernate or save power in any way(I had to do this many times before ).
I Have selected to 'Do Nothing' when shutting the lid, also i have De-selected 'allow windows to turn off device to save power' in the wireless adapter settings .
I have scoured and searched the forums . I have Tried all the given remedies , as mentioned above. . I even reinstalled several versions of Utorrent - No Joy
According to the power options , the computer should be un-phased and continue downloading , as I have done so before .
Could it be the new Utorrent version , or is there some kind of problem with windows?. As mentioned above I have downloaded torrents with the lid shut many, many times before . I am aware of the power options , and although the computer doesn't sleep , hibernate or shut-down now , the torrent download speed is lost as soon as I shut the lid
Any solutions for this ?
Since you checked the usual suspects already, I don't have much to offer off-hand.
Maybe I can help you see what's going on though. Take a paperclip, hold it loosely and move it over the frame of the display to find the small magnet that triggers the lid close sensor when you close the notebook.
Use a small magnet on the corresponding spot on the palm rest and see if there is any message by utorrent or whatever utilities you deem appropriate (sysinternals?) to investigate.
