Hi guys...
Due to ever increasing problems with Direct X 9.0 and Service Pack 2 I have decided to reinstall Windows XP Home onto my FR415B Vaio.
The reason I am going to use Home is that I tried to install XP Pro on it when I first got it and the drivers for Function Keys etc would not work...
My question is... If I format and reinstall will I be able to download all the drivers for the hardware (ie the screen, pointing device, function keys etc)
I have lost the original recovery disk and will be reinstalling windows using a seperate copy...
Please help me!!1
You can do exactly that, and still keep XP Pro. Head over to the downloads section of www.vaio-link.com and download the 'Original Drivers Package.' The Fn Functions key software should be in there, along with all the other main component drivers.
If this works I will let you sleep with my sister. seriously...
Yeah if you go to:-
http://www.vaio-link.com/downloads/downloads.asp?l=en
Select your model and then you should get a list of the drivers etc. There is even a "Defult Drivers" download for most models. This gives you the drivers which are shipped with the laptop when new.
Hope it helps.
Jon
How did I know you'd reply DT????
:smileyblush: :smileygrin:
Haha, she is not bad. Not my type, but then I don't go for members of my immediate family...
Anyway guys, I am about to reinstall using xp pro instead of home like suggested. Are you sure the original sony drivers i am about to download will work with this?
also the reason i am reinstalling is because media player, quicktime and real player have all stopped functioning properly and NOTHING i can do will sort this out.
I have checked dxdiag, i have scanned all the system files, and i have checked dsound.dll (which is causing the problem) and nothing appears to be wrong...
If anyone can help me on this I might even get another female (or male) member of my family involved
Can you be more specific? "Not functioning properly" is a little vague.
