Wireles cannot see the network
euripyd
Hi!
I have VGN FS195VP notebook.
I have installed Netgear router.
I have broadband internet.
My LAN contact with the cable through the router works well, but wireless network doesn't.
Simply, when I refresh to see availible networks I don't see any.
Netgear is working properly and wireless light is green-ON.
On my computer wireless is enabled and switched on.
I use: obtain IP adress automatically.
Why I don't see any network?
Here around should be several networks availible but don't see any.
I HAVE TRIED TO FIND SOLUTION WITH SEARCH THE FORUMS but not succes.
Help!
10 REPLIES 10
Thalamus.
Champion
Hi euripyd,
In you Netgear Router management, under wireless settings, turn on Allow Broadcast of Name (SSiD) then click apply..
Then refresh to see available networks, is your network visible now..?
euripyd
Thanks SOLVED!!!!!!!!!!!!!!!!!!! :slight_smile:
Thalamus.
Champion
:cool: You're welcome... :slight_smile:
kee-lo_
My wireless network decides to hide itself too
VaioWoman1
Oh Poor Kee-Loo
Perhaps as a "Thank You Jesture" for always being there for us, we can help you for a change?
"Thats a laugh" Tee Hee
!laugh.gif|___jive_emoticon_name=laugh|jivemacro=emoticon|class=jive_macro jive_emote|src=laugh.gif!
kee-lo_
:wink:
Seawit
If you try the solution pointed by Thalamus you will be able to solve the problem. But keep in mind to use an encrypted password to access or else all your neighbours will be able to use it also... :laughing:
:tongue: :wink:
kee-lo_
Using WPA now
Seawit
So i can assume now that you have your problem solved? :clap:
