wireless home network
spider.s3
hi
i have made a wireless network at home with 3 computers. it all works ok, but for just one problem. all the computers see each other, but the Vaio will not let the other computers access it. it asks for a password. but i never set one up for it. the sony is a Vaio VGN-A115Z. Does sony set a factory set password ?
thanks
7 REPLIES 7
TygerTyger
I've never heard of Sony setting a password for networking. Are you really positive nobody else has set a password? If nobody knows it and you don't mind doing it perhaps you are better off just deleting that network and setting up another one without a password, which is in fact what I did.
William
Is there more than one user account on that computer?
William
Twisted-Rizla
It should be the same password you used when you registered the vaio.
kee-lo_
Thats odd, normally you set a password for shared folders.
Did you buy it from a retail store?
spider.s3
all sorted. i must stand in the corner with a pointed hat on with the letter D on it for DUMMY. why i here you ask, well i forgot to share the bloody folder.....roflmao.
D'oh
William
Just goes to show that you should never overlook the obvious.
Pleased its sorted.
William
kee-lo_
WOW I got a networking question right.
