WLAN problem - VGN-AR21S
FrankP
I have a problem with my 2-week old VGN-AR21S WLAN.
After 5-10 minutes it loses the wireless connection. The WLAN green LED goes off and can't be turned back on by sliding the switch back and forth or trying to Repair the connection.
Any ideas? Does it need to go back under warranty?
rich912
Hi FrankP and welcome to the forum.
Another member reported that he solved this very problem with an AR21S by upgrading the Intel PROSet/Wireless Network Connection Software from here .
Please note the disclaimer re OEM software….
Original thread .
Go n-éirí an bóthar leat
