Word Keeps Crashing Ahhhhh
induct
MS Word 2000 keeps crashing whenever I use it. I know it might be impossible for people to help but any help would be great.
I can put the error online if it helps.
20 REPLIES 20
kee-lo_
If you could we'd be grateful.
What are you doing when it happens?
SilverZero
as a last resort you can use open office, www.openoffice.org, its free, and its rock solid and can import word docs, and also write to doc, so no problems with workflow.
profile.country.de_DE.title
seb21__
last resort?
OpenOffice is my first resort!
induct
Kee-Lo
It usually crashes within 10-20 Sec of starting program:
My Photoshop CS was (untill I went back to PS 7) doing the same thing, so it could be connected with the resorses. Have a look at what running and see if you can make sense of it:
kee-lo_
Ed,
You probably should reinstall Word first, see if this helps.
induct
I've done that.
Do you think it could be a virus/worm even though I run Ad Aware and Norton regularly.
kee-lo_
No I don't think it's a virus
induct
From Task Manager what on earth is VzFw.exe
robpaxton
It's Vaio Zone/Gigapocket or one of it's subprograms.
See this for info
