Just bought s brand new vaio x505, wah.....so sexy!!!!
however, after i switched it on, the pointing anchor keeps going upper right corner, and sometimes keeps going to lower left corner. It drove me mad!
I also realised that the movement of the anchor changes speed when i move the screen.
I personally believe that is a hardware fault,since i tried to disable the pointing device and use a external usb mice, no problem at all..... however, it is rediculous to bring a fat nice around with such a sexy slim x505, isnt it??
Anybody else have the same or similar problem?? please help!!! Thanks a lot!!
When the pointer moves, are you touching the pad at all?
Of course not touching it at all! and the laptop is placed on my study table...
Plus, the anchor moves faster sometimes, and also slower sometimes.......
any idea?:smileysad:
Sorry, we have to check all posibilities.
Sounds like there's a wire loose in the touchpad.
As it's in warranty I'd get Sony to fix it.
Hi
Thanks for suggestion!
Judt called sony up, arraged a pick up for monday.
Hopefully that is not going to take too long!
Cheers mate
No problem.
Average turn out is 4 working days.
It seems that you are very familiar with sony products and services! You work for sony? I would be very aproud of myself if i were with you knowledge.:smileywink:
nah it wont take long, theyre pretty efficient with their pickup and return service from what ive heard,
just not to efficient with the actual fixing bit
