XP installation CD?
Murdoc83
XP installation CD?
I have bought a Sony Vaio FE11S. What do I need to do when my notebook asks to place the Win WP cd?
25 REPLIES 25
Murdoc83
No, I first wanted your advice on this.:smileywink:
The following is my boot.ini:
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(2)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Windows XP Media Center Edition"/fastdetect/NoExecute=OptOut
So... can changing my NoExecute=OptOut in No Execute=alwaysoff help for solving the explorer.exe error?:smileyconfused:
Thalamus.
Champion
Have you tried using system restore to restore to a point before the errors occured?
Start > All programs > Accessories > System Tools > System Restore.
Murdoc83
I only have this computer 4 weeks so I did one 2 weeks back but it still occured.
What's the difference between recovery and restore?
I assume restore is quicker and your files are still available?
If I recover will my D partition also be erased?
carthorian
You can choose to restore your C drive to factury settings (= new), you can also select to set C & D drive to factury settings, but you don't need to do that.
Thalamus.
Champion
Restoring your computer does not affect or change your personal data files.
Recovery uses the VAIO Recovery Utility
Yes
Not if you only select C: drive recover (recommended)
Murdoc83
I changed Optout in my boot.ini to alwaysoff and since yesterday i haven't had any more errors about explorer.exe.
Thx for the explanations and help!
Greetz
Thalamus.
Champion
:cool: Good news :slight_smile:
Murdoc83
No it isn't fixed :slight_frown:
Any more suggestions?
Thalamus.
Champion
:slight_frown: Have you tried the system restore option yet?
Murdoc83
Does this mean my installed programs and favorites will still be there?
I will have to ga 4 weeks back to be sure.
