Could someone tell me if its true that this machine will not take an installation of xp pro due to its internal architecture?
we bought one tried to upgrade it to pro to connect it to our servers and some hardware doesnt work.
regards in advance
Peter
Peter: I am so sure someone posted the link, I can't find it though.................
Atika: Unless you need advanced networking and domain server access you really don't need to get a new laptop for XP Pro.
Yes the extra features in XP Pro are not really needed at home.
I haven't had a problem installing XP pro on mine (I *hate* xp home and all the junk sony install).
I'll be installing freeBSD on a second partition next week and dual-boot the two.
LOL, You wouldn't need the most features of XP Pro. What you want do with your PC. For Home using, XP Home is more than enough.
I'll be installing freeBSD on a second partition next week and dual-boot the two.Hehe, I wish you fun with the installation. Don't forget that Unix, Linux, Gnu and CO. only recognize 32MB RAM of your NVIDEA graphicscard. The Intel GM graphic could have problems with OpenGL. One my PCG-FR it works only in Software Mode which is really slow.:smileytongue:
If you do change OS, don't delete the hidden partition with the recovery information. I might always be usefull in the future.
And make a backup of the folder c:/drivers and of c:/ultils
You can always download them as well, but just to be on the safe side ...
I've not had a problem with another notebook with integrated intel graphics... I'll have to see how it goes.
I have been told that the machine cannot be upgraded to pro as the home version is SP2 and the upgrade version is SP1 so when you try to upgrade it just says that you cannot upgrade as a newer version is installed.
Please help I am tearing my hair out on this one and Sony are as much help as a brick.
Question is whoever upgraded or put the full install of pro on which drivers did you use to get the thing working?
regards in advance
Peter
regards in advance
Peter
