XP PRO upgrade on A417S Notebook
dave100
My VGN A417S is now working fine having had a replacement HD and DVD drive. Anyway my Q? is regarding upgrade to XP PRO. Has anyone tried it and if so any problems?
:slight_smile:
rich912
There are no problems in upgrading to XP Pro – the struggle starts when you need to install the Sony applications. I have done this but didn’t need or want any of the pre-installed applications, just the utilities - no problem there as they are available on Vaio-Link.
There are ways and means but it is not always straightforward. Have a look at this guide produced by James, a fellow CV member . LINK
I assume that you desperately need one or more of the additional features that XP Pro includes?
Go n-éirí an bóthar leat
