Dab radio XDR-S7 Power plug
Simple question.  Is the black and white  wire on plug pos or neg?  Thank you.
Hi there
Simple Answer: Considering you have asked this question, indicates that you should not be touching it.  The only way to be 100% certain is to test it with a multimeter
But found this for you:
http://electronics.stackexchange.com/questions/39450/what-do-solid-striped-lines-on-a-wire-indicate
