mex bt 3900u
montstpere
mex bt 3900u
can i connect my mex bt3900u to a peugeot 206 steering wheel controlme
Drumzman
Hi montstpere,
I would say this should be possible using third party accessories.  Basically you will need a steering wheel control adapter specific to your car, and then a patch lead that is specific to the make of stereo you are using.
I've used these guys before, and been very happy, but I'd suggest perhaps giving them a call to make absolutely certain on compatibilty before you buy.
http://www.connects2.co.uk/
Hope you find something that works for your car.:smileyhappy:
Drumzman
Hi montstpere,
