NW A45- Music on memory card not showing on Walkman
Leodis41
Well I bought a second hand A45 last week and seem to be having issues adding music to it.
Using the the Music Centre I have transferred my music to the memory card in the unit. When the Data base has built only half my music has transferred, yet everything is MP3 or MP4.
If I check the file folder its shows all the folders for each artist but they are empty.
I am using a new Kingston 256Gb card.
Any advise would be gratefully received.
4 REPLIES 4
Peter_S.
Genius
Are you using a compatible audio format for the files?
All the supported formats can be found here:
https://helpguide.sony.net/dmp/nwa40/v1/en/contents/TP0001449072.html
Peter
Leodis41
Yes, MP3 and MP4, anything unsupported would be converted, but supported files aren't copying.
Is there a limit to how many files can be moved at once? I have over 10000 tracks I want to add.
Sonyvores
Music center not good with too many songs transfert at the same time. do little by little like 100 by 100
Joe_Dohn
Specialist
You can also use Windows Explorer.
