Setup.exe not on walkman
snotyboty
Hi there,
I just got a sony NWZ-S765 and I tried to load the bundle software but 'setup.exe' does not seem to be present on the Walkman. Any help?
Also when connected to my laptop it shows 'Connected USB (MTP). The player cannot be operated'. Is this a problem?
Kind regards,
Scott
5 REPLIES 5
OriginalJ4Y
Hi
I have exactly the same problem as you atleast concerning the lack of Setup.exe anyway.
Jay
Edit - I just ended up downloading Media Go from here http://mediago.sony.com/enu/features
Message was edited by: OriginalJ4Y
meristi95
kulaklığı bilgisayara takınca setup exe yi açamıyorum.kulaklığı görmüyor bilgisayar(windows 😎
Pascale_F
Moderator
Hi meristi95,
Thank you for posting, but you'll need to browse Sony Turkey about this.
Best wishes,
Pascale_F
resavar
Pas de setup.exe évident à trouver sur un NWZ-E585 au moment de la première utilisation et donc "The player cannot be operated". Je m'aperçois que le problème ne semble pas être nouveau mais je ne connais pas la réponse donnée à mes prédécesseurs
jumpsuit
Hi there
Did you try the solution of downloading media go posted in one of the threads above?
Have you tried resetting your walkman?
