Songs are out of order on walkman
johnmc14
Songs are in the correct order on the software.  They are not in the right order on my Walkman.  I checked the properties on the software and on the Walkman.  The songs are labeled with the correct number.  This is only on a few albums.  I don't know how to fix this.  Any help?
Thanks.
5 REPLIES 5
Hi there,
Which model do you have?
Best wishes,
M
johnmc14
NW-A55
johnmc14
NW-A55
Joe_Dohn
Specialist
I've just found these suggestions in the help guide of the Walkman which mention using playlists or bookmarks. Here's the link: https://helpguide.sony.net/dmp/nwa50/v1/en/contents/TP0002342858.html
BB_Wolf
Dude, if you, or anyone has this problem, the solution is to go to Device Settings and in Reset/Format list do Rebuild Database. It seems to be different than rebuilding the database after we turn the player on - this one took  longer and in the end it arranged all the files in the right order. I did it with my Walkman connected to a computer via USB, but it should also work on its own.
