I have a Sony MD-N710. I am having great trouble installing Sonic Stage 4.3, the latest version.
Initially it couldn't find certain files which may have been for Windows Media Player.Tried a reinstall, now I get a
(2051,20698)
I think it may be related to a system restore done recently,but not sure. I tried removing Sonic Stage references in the registry, sno luck.Initially there wasn't any add/remove programs for it,although the Sonic Stage icon was pinned to the there Start button and would try to load ,but was missing files.
Is there any utility anyone can recommend to completely remove traces of the program? Tried CC Cleaner
What is your OS, because It's known that Sonicstage is not compatible with Windows 7...unless you use some specific versions...
