SRS -X7
oliverPS
SRS -X7
Hello
I have an SRS -X7 speaker and it moves when in use.  It moves so much that i have to reposition it every now and then so that it doesn't dance off the edge of the shelf that it is on.
It does it too if i put it on the table so it isn't to do with the surface that it is on.
I have tried a non slip mat under it but it still moves when on this.
Do you have a solution please?
Regards
Oliver.
10 REPLIES 10
Hi there
I have had confirmation that they have now seen my escalation to your posts here.  They have confirmed that this is not a common problem.  They will be in touch soon.
