Walkman NW-A25
edstewa
Walkman NW-A25
In the play back screen when listenning to music the green progress bar disappears is this the correct operation of the player or should it always be diplayed as I think it should.
The title, album and artist are displayed.
Thank you
Mr Edwin Stewart
Sonyvores
yes that's normal 😃
Sonyvores
yes that's normal 😃
edstewa
Thank you for the reply
Mr Edwin Stewart
