WH-1000xm3 wired witt mic windows 10
Hi All,
I am using the headphones with my work laptop .. so no bluetooth available.
Using the wired option worked with the old thinkpad but not with the hp g5 elitebook.
I guess both are using the internal mic on the laptop s the SONY cable is TRS not TRSS.
What 3.5mm jack TRSS cables are compatible with these headphones ?
RODE SC9?
Geekria Quickfi ?
or any TRRS jack wih is own mic will work?
HannahEd01
Community Team
Hi jagmahal66, there are nor specs mentioned about the cable on the support page. but I'm guessing it has to do with the computer itself, not the headphones.
