WH-H910N PC connection problems
ANewbiePlays
I've recently purchased the above headphones and am having difficulties with using on my PC.
I bought a Bluetooth adapter with wireless 4.0+EDR which plugs into a USB post.
I can connect to the PC but the sound is only coming through in maybe half second bursts and then nothing for 3-4 seconds.
As far as I can tell all the drivers are up to date and theres no issue with the PC so I'm not sure what to look for next.
any advice welcome
Many thanks
Peter_S.
Genius
Might be an issue of the BT adaptor. Maybe you're not using the latest drivers.
Peter
