WH1000-XM4 fastest charger
Mattlcfc
Hi. Anyone know what is the fastest charger you can use. Is it safe to use a 25 watt charger ?.
Thanks in advance
8 REPLIES 8
IamNic
Hello @Mattlcfc,
chargers can usually dynamically adjust the current depending on the connected device (the device "talks" to the charger).
Therefore I would simply try it - if it doesn't work, the headphones will refuse charging (I never heard of anyone damaging them) and if it works, the headphones will charge at the maximum speed it supports in combination with the charger.
- Nic
Mattlcfc
IamNic
Hello @Mattlcfc,
you're welcome - if you don't mind - would you please do a followup on this topic?
Maybe it helps someone else with the same charger to know what behavior to expect from it.
- Nic
Joe_Dohn
Specialist
@Mattlcfc Did this work for you?
Mattlcfc
All works OK on samsung super fast charge. Sorry for the delay .
I am doing a timed charge atm as the battery has only just ran out.
Joe_Dohn
Specialist
No worries and thank you for the update.
Once you're done charging it, could you share the specs of the charger or the model of it (if there's one) and mark the thread as solved so others can know what to look for?
- JD
Mattlcfc
Samsung 25w superfast  charger and Samsung usbc lead
Mattlcfc
Question solved  many thanks
