Access to sd-card after upgrade on 4.4.4
vvs100
 After upgrade Zony Experia Tablet Z (LTE) till Android 4.4.4 tablet PC cannot find sd-card
profile.country.RO.title
_alexdon_
There is restricted access on 4.4.2 too,but only that 3rd party apps cannot write on SD.
alexdon
9 REPLIES 9
_alexdon_
alexdon
vvs100
How resolved this problem? Android cannod indentify sd card phisically
_alexdon_
You can try to remove the microSD,turn off the device and put the card back.Turn on the device.
alexdon
vvs100
Sorry, but you recomendation don`t resolve problem.
vvs100
Thanks, problem resolved!
_alexdon_
Great.
alexdon
martinmrmus
couldn´t sony add some bypass for 3rd part apps?
_alexdon_
Really do not know.
alexdon
Metoda84
Hey! How did you solve this problem? My tablet soesn't see the SD card at all.
